Is it worth me investing in a system or separates?
Discussion in 'Home Cinema Buying & Building' started by Calvados, Jan 7, 2005.
  1. Calvados
    Calvados
    Jan 2, 2005
    116
    +3
    ...in an all-in-one system eg DHTs500 if I need a DVD recorder?
    I put up a similar post a few days ago but didn't really get a solution.
    I have about £500 to spend and was going for an all-in-one but I need a DVD recorder (because I don't have Sky+).
    Can anyone recommend a system that incorparates a DVD recorder?
    Or should I buy separates for my £500? And if so, I'd really appreciate recommendations. I'd prefer discreet speakers whatever I get or I'll be in trouble with the boss.
    many thanks in advance, Calva
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    the only way you will get an amp speakers and dvd recored + cables for £500 is if your talking really low budget low end stuff. and quite frankly it wont be much cop. to get a decent setup ypud be looking at a panny E55 dvd recorder, denon 1705 amp and maybe some Tannoy Fx 5.1's. this would be a decent starter setup but i think it will be more along the lines af £6-700. alot of brands are incorporating dvd recorders into AIO's like panny, jvc & sony. last time i checked they were well above £500
