Is it worth me getting sky+
Discussion in 'Sky Digital TV Forum' started by tiger3176, Jan 5, 2005.
  1. tiger3176
    Hi all, I have a Toshiba rd xs32 HDD dvd recorder. I also currently subscribe to NTL. The Toshiba has time slip and does all the other things that it seems the Sky+ does, but can only record 1 channel. If I got Sky+, could I therefore record 3 channels using the Toshiba for 1? It may seem a silly question but I genuinly don't know. So what I'm asking is, I have the Toshiba that you can record to hard drive or DVD and cable television. Could I do a lot more if I subscribed to Sky+? Or would I just be getting the facility to record 2 channels at the same time? Thank you for any help.
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    Chorley, Lancs
    Certainly with the cable box going into the Tosh (or aerial), and the Sky + box recording 2 channels, you could record 3 channels at once. It would be expensive though, if you still subscribe to NTL. If you tossed NTL, then you would only be able to record 3 channels using the aerial as the third input (to Tosh). Sky +'s advantage over an HDD/DVD recorder is the ease of use EPG recording facility, plus the 2 channel record thing of course. Also you can watch another recorded program whilst recording one or two others.
