Is it worth me getting a projector?
Discussion in 'Projectors, Screens & Video Processors' started by Marky P, Jan 29, 2009.
  1. Marky P
    Marky P
    Right!:)
    My room is 10 foot wide wall to wall. Is it possible for me to fire a projector along this width and get a decent size picture? I currently have a 50" plasma and was thinking about a PJ if it would be much bigger than that. And what sort of price are we talking about for a full HD PJ and a motorised screen?
    Ta!:hiya:
  2. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    Depending on which projector you buy you should be able to get a 70"-80" diagonal screen size with a 9ft screen to lens dimension.
    Hd pj's start at around £1000 and an electric screen £300 ish or manual £100 approx.
  3. IWC Dopplel
    IWC Dopplel
    Sep 11, 2008
    4,019
    134
    BATH
    +531
    I would review how far you are going to sit from the screen and how much you are prepared to compromise/darken decor.
    I short if you want a bright white room as it is small you will not get a good performance out of a cheap projector (Or any for that matter). Regarding viewing distance circa screen diagonal divided by .84 is a good starting point for a screen
  4. swiftpete
    swiftpete
    Sep 30, 2006
    5,185
    Notts
    +1,294
    I had a smaller room than that and had good results from a projector. Mine was 8ft 9 wall to wall! The screen was only 80 inches, but that is much bigger than a 50 inch screen.
