Is it Worth It?
Discussion in 'Subwoofers' started by funlovincrimnal, May 28, 2004.
  1. funlovincrimnal
    funlovincrimnal
    Hi All,
    Is it worth investing in a sub and then connecting it with a yamaha prologic amplifier with a 6 channel discrete input and DVD player doing the DD/DTS decoding.
    Will the sub perform as good as connected to a DD/DTS amplifier.
    Another thing, should I hook the sub directly with the DVD player (with a built in decoder) or connect it with the prologic amplifier sub out. Please help
