is it worth going from 5.1 to 7.1 with my 757se need rundown
Discussion in 'AV Receivers & Amplifiers' started by lodwales, Nov 2, 2005.
  1. lodwales
    lodwales
    Oct 7, 2005
    58
    had my new yamaha 757se today and see that is supports 7.1 sound, it has rear back speackers, i have rear speakers but how much difference will rear back make to the system, another question is that you can also add front speakers b and also presense speakers what is the deal with all these speakes please anybody give me a rundown on this !
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Fitting rear speakers can fill in the back of the soundstage and will allow you to get the best out of the :dts: ES 6.1 soundtracks.
    Presence speakers will only work with a 5.1 setup and can expand the front soundstage with different soundstages. I have used both and decided to just use the rears as although the presence speakers do make a difference the rears make more :D.
    Try both ways and see what you prefere. :lesson:
  3. Mickey G
    Mickey G
    I am also currious about this. I would have thought that the presesnce speakers would be more useful as I've found not a lot of DVD come with DTS.
    Also I was wondering if I could use my TV speakers as the presesnce speakers. Has anyone else tried this?
