Is it worth getting a dedicated Subwoofer cable ?
Discussion in 'Subwoofers' started by dUnKle, Dec 12, 2001.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,746
    +2,719
    Considering a 3 Meter IXOS dedicated sub cable, is it worth getting a dedicated cable
  2. flunchy
    flunchy
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,746
    +2,719
    whys that then
    At present I am using a phono cable which was originally for sound out on my DVD player, it cost around £80, will a dedicated cable be better than this ??
  4. flunchy
    flunchy
    Why didn't you put this additional information in your original question? :)
    If you are using a cable designed to carry the digital signal from your DVD player to your receiver as a sub cable, then I would expect that a dedicated sub cable would sound better. A good sub cable is designed to carry low frequency analogue signals to your sub, whilst rejecting interference from higher frequencies - especially over longer lengths. A digital cable is designed for a very different task.
    If your current cable is a high-quality analogue phono, and you're happy with the sound, then I wouldn't bother changing. That said IXOS 3m sub cables start at about £9 so you could just buy one to experiment.
