Is it worth buying from USA?
Discussion in 'AV Receivers & Amplifiers' started by jzee3, Sep 19, 2007.
  1. jzee3
    jzee3
    Jan 25, 2007
    96
    11
    +8
    Hi Guys,
    I have an opportunity to buy a receiver from the USA as I have a brother out there who could buy on my behalf and ship to me in the UK.
    Apart from the hit with import duties are there any other things I should take note of before I ask him to buy one for me?
    I see that due to the strong pound, I can buy most things out there for half the UK price. This makes it very tempting indeed.
    Would I need a transformer to use any of the AV Amps that I buy from USA?
    Thanks for all your advice in advance.
  2. Member 6435
    Member 6435
    Dec 18, 2000
    1,518
    Tunbridge Wells
    +324
    Afternoon
    On top of import duties you need to factor in VAT which is also payable on imported goods. Also worth also checking the warranty side of things.
    Regards
    Alastair:hiya:
  3. Skiprat
    Skiprat
    Feb 11, 2007
    1,390
    Stewarton
    +147
    Yeah the VAT will be calculated on the total of cost of goods, shipping and import duty and will be at the standard rate of 17.5%
    Skippy
  4. df1603
    df1603
    Aug 14, 2002
    345
    +13
    you'd need quite powerful step-down transformer to run it (depending on the power rating of the receiver), unless the receiver has switchable power inputs, some models have such option available or can be converted easily. Also the tuner/radio part might not work properly due to different FM FQ spacing in the US. Warranty will be most likely US only, again manuf. dependent...and do not forget shipping cost, it may be quite expensive for heavy unit....
  5. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    Don't forget "Tuned for UK ears" !
  6. javelin_
    javelin_
    Aug 2, 2007
    158
    +8
    Ask for multiregion version if available. It should have all settings and I think such versions are mostly distributed for Asia. If you decide on Onkyo, they use to have specification related to the versions for different markets.
