Is it worth buying a HDMI DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by dancuprar, Sep 10, 2005.
  1. dancuprar
    dancuprar
    Sep 10, 2005
    16
    I currently have a Panasonic TH-42PV500 + SONY DAV-S880. Would i notice much difference when playing DVD's if i were to invest in say, the New Denon HDMI player for £250 :thumbsup: .
    Thanks for your time
    Dan
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    as a rule of thumb, if you have good kit already you are unlikely to notice a huge difference, with cheaper kit there may be benefits, emphasis on 'may' though, all down to how it is done not the interface itself. If you currently use a component connection then the merits are MORE likely o be 'minimal' but there are loads of other advantages, lack of cables etc etc with HDMI.
