Is it worth buying a 1080p LCD TV/Screen Size - Please help this newbie
Discussion in 'General TV Discussions Forum' started by sgriff, Jan 12, 2008.
  1. sgriff
    sgriff
    Jan 12, 2008
    2
    I am looking to purchase a new tv. Probably a LCD tv as we have a french window 12ft to the left and I’ve heard about glare problems with plasmas.
    I'm looking for a tv which won't blur when I watch football. The show room salesman said to go for a 1080p tv. Looking online, I discover that Sky only broadcast HD in 720p and 1080i. Am I missing something - will having a 1080p tv make any difference to having a 1080i or 720p tv for watching sky broadcasts, especially sport?
    On a separate note, I'm not sure what size tv to go for. The various salesmen recommended a 37" (we will sit 9.5ft away). However, looking online I've come across lots of different advice. Some places state that bigger than 37" at that distance will result in me seeing pixels, others state I won't see any difference watching a HD broadcast as a 37" screen is too small! I'm very confused!
    Thanks in advance.:lease:
  2. richiej
    richiej
    Jan 7, 2008
    1,738
    London / Herts
    +98
    Welcome to the mad house....... I'm in the same boat. :thumbsup:
    I'm probably going 37" but no bigger, and too am tempted to go 1080p in order to get "the best" or at least a "better" picture that will also benefit from tomorrows broadcasts ;)
    I look forward to other replies and suggestions on this thread :)
  3. Windtalker
    Windtalker
    Jul 8, 2005
    1,703
    48
    newcastle
    +51
    if you want the best out of bluray, and watch alot then id say go for 1080p :thumbsup: if you dont id get a good hidef tv plasme or lcd,just depends on what you will be doing most.i myself can only see a slight see a slight differance on bluray on a 42" lcd :rolleyes: imo gaming looks good in 1080p :D but full HD games are few at the moment,and i think that 720p games look worse on a 1080 screen for some reason.
    if you want it for sd material and sky hd id say get the best price plasma you can afford 720 or 1080 :smashin:
  4. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Here's the science behind resolution and viewing distance that may be of interest. This applies to any type of pixel based display.
    http://www.audioholics.com/educatio...derstanding-1080p-resolution-in-displays.html
    There will be no issue with visible pixel structure even at basic SD resolution at the viewing distance/screen sizes you mention. Pixel structure only becomes an issue at much larger screen i.e. a projector at your viewing distance.
    AVI
