Is it Worth adding Banana Plugs??
Discussion in 'Cables & Switches' started by Cwhelan, Mar 4, 2005.
  1. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    Nearly finished my AV setup! it's taken 3 months last Job (maybe?). I keep having nightmares :mad: fittting the speaker cables into the back of my AV amp, there has got to be a better way??
    Is adding Banana Plugs the Answer??
    Views greatly appreciated?
    CW.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +271
    Depends on how often you're going to want to disconnect them. An extra connector at the end of the wire is just another place where there could be a vulnerability to poor contact.
  3. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    good point! it's just a pain in the **** :oops: excuse the french! If I was to do the Job what type of Plugs should I go for? Make etc??
    + will normal Silver solder do?
    Cheers,
    CW.
  4. phresh
    phresh
    May 10, 2004
    215
    Oxfordshire
    +3
    The best thing to have doe was got QED Airlocs fitted when you bough the cables. Not sure if anybody will do it after they've been purchased though, could be worth a look.
  5. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    I don't mind doing the soldering! it's just making sure I get some decent plugs!
    Couldn't get the fitted as I did the install myself & buried all the cables in the walls. :smashin:
    The search continues.........
  6. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
  7. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    Cheers will get them ordered today! :thumbsup:
    CW.
