is it worth £300 ??
Discussion in 'Subwoofers' started by scottyboy123, May 19, 2004.
  1. scottyboy123
    scottyboy123
    Feb 23, 2004
    3
    chesterfield
    just been trawling the u.k. superfi site and iv noticed they are selling the tannoy revolution r15 sub for just under the £300 mark, anybody got any comments ?? good or bad
    cheers
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,539
    +520
    Somebody did make a posting on this some months ago, asking the same question. General comments were not positive. I don't think it's as good as the new MS309 (I think it's called) sub which is even cheaper than the Tannoy.
    CL
  3. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    It's a 15" sub!
    Surely it must go lower than a 309.
  4. GJC
    GJC
    Mar 1, 2002
    2,137
    London
    +69
    Bigger is not always better - Just look at the MJ Sub specs :devil:
  5. scottyboy123
    scottyboy123
    Feb 23, 2004
    3
    chesterfield
    the problem is i have a pair of floorstanders at the mo, so i need a sub that will go down to around 20hz at that sort of money. can anyone recommend any alternatives ?? :lease:
  6. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    I still don't think it's fair to compare the 2 subs.
    I've never heard either, but the laws of physics dictate that the 15" sub will move substantially more air.
    Has anybody actually heard the Tannoy sub?
  7. chubbs
    chubbs
    Mar 13, 2003
    109
    16
    leeds
    I have a Vibe stealth beta sub which will go to 20hz, it's 8 months old, in black, remote control, mint condition for £300. I have the box and instructions.
    It's a great sub, I wouldn't be selling it but I have just got a THX set up and want to keep the set matching.
    If your interested in it then I will put in on the classifield section and you can get it through there. I'm based in leeds.
  8. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    i don't think you'll find a sub for under £300 at the moment that truely gets below 20Hz - the MJ acoustics claim to but everyone seems to take that with enough salt to trigger heart attacks...
    depends on whether you want a sub that is also good with music or just one that has plenty of slam.
  9. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
  10. drum63
    drum63
    Nov 20, 2003
    147
    Kent
    +9
    In my room the XLS is reasonably flat down to 25 Hz but is 6dB lower at 20Hz.
    This was measured using sine waves and after correcting for the Tandy SPL metre.
    It will depend on where you position it though and other characteristics of your room. You might get higher output at low frequencies in a corner.
    Mine is about 3 ft from corner along the front wall.
    Doesn't sound very good down at 20Hz (distorted), but I've not heard an expensive sub playing a 20Hz sine wave so that may be normal.
    Gary
