Question Is it weird that I dislike my speakers for TV/Film, but love them for Music?
Madao
I have the following gear
Yamaha A-S501
Q Acoustic 3050i.
I'm really happy when listening to music with them, but just don't find this setup enjoyable for watching TV/Film and more often than not just use the TV speakers even if they are under-powered. Just wondering if i'm doing something wrong after spending so much on audio gear.
jkbmusic
IMO your Q Acoustic loudspeakers will be far superior in sound quality to that of the television. If you are playing your TV sound source signal (Audio out), via the Amp, then it also should be far superior to the TV speakers.
gibbsy
That's an odd statement, usually it's the other way around. Films are brilliant but stereo music is crap. Have you run the room EQ on the Yamaha?
MaryWhitehouse
That’s a stereo amp I don’t think it has any room eq.
How is everything connected up?
gibbsy
MaryWhitehouse
Ah my bad. Though I was still modding the receivers.:blush:
Lol that amp should sound fine enough for this so I suspect there’s a problem to be solved.
gibbsy
Yes agree. It was the mention of film against music that threw me as well.
@Madao A photograph of the speakers in their current position would help. Also what is your music source and how do you have the TV connected to the amp.
AudioJosh
How good is the sound card in your PC? That's what you would be using to decode the sound if you're running a 3.5mm to RCA cable from PC to Amp. People often use external DAC's bridging between PC and Amp to improve the sound (I have done this myself as the DAC in my Macbook Air sounds a bit naff).
Might be worth you trying an optical cable from TV to Amp to see if that improve things? You'd then be using the DAC inside the AS-501 to decode the sound and it's not a bad one.
EDIT: you could also experiement to see if things sound better with the Pure Direct button on the amp switched on if you haven't tried that already.
Madao
I can't take a picture at the moment, but the place im in right now is less than ideal.
1.5 foot from the wall (from behind the speaker)
1 foot from the wall ( from the side of the speaker)
4.9 foot between speakers.
If this is the problem at least it's a temporary one.
Might be worth you trying an optical cable from TV to Amp to see if that improve things. You'd then be using the DAC inside the AS-501 and it's not a bad one.
I can try this later.
gibbsy
Optical would help and set the TV to output bitstream and DD.
MaryWhitehouse
Ditch the 3.5 to RCA and find a way to let the amp decode everything. The tv at least can send optical to the amp once you’ve sent via HDMI to it. Can you get a coax out from the pc to the amp for music?
Madao
Not at the moment. It's just from the motherboard and it has no coax/toslink. I was looking at inexpensive options to achieve this, but I couldn't find much available in the UK at least.
MaryWhitehouse
What’s the source for videos. Netflix etc or stored files? As audio for both arrives by the same route I’m thinking the source files aren’t good?
gibbsy
The 3.5 will be the headphone out and this isn't the best option for audio by a long way. Almost an after thought on a lot of TVs.
MaryWhitehouse
The 3.5 is from the pc.
gibbsy
Once you put PC in the answer that's me out. I currently typing on the modern equivalent of the abacus. There should be a very good Netflix and Prime App on the TV though any subscription to both would allow several units running it and an optical connection using those Apps should sound a lot better with the Yamaha doing the decoding. PC could be a very weak link.
Joe Fernand
AVForums Sponsor
How is the audio playback of Video files configured on the PC - hopefully 2.0 (Stereo) with no Sub?
As others suggest the 3.5mm Output can be pretty poor quality, and noisy, on many PC’s.
You have three options to consider:
1. PC HDMI > TV then TV Optical > Amp - and use the DAC in the Yamaha.
2. USB to Optical Adapter - and utilise the DAC in the Yamaha.
3. USB DAC - and bypass the Yamaha DAC.
The first option ought to work fine.
All of the options require correct positioning of the loudspeakers within the room, relevant to the TV and relevant to your seating position.
Joe
Madao
stored files
Yeah, files. Source audio is good quality.
Yes. 2.0, but I have to downmix some audio to stereo. I don't know if that could be causing problems.
No sub.
I didn't realise this would work... shows how little I know.
I might be confused how these work or I'm looking at the wrong product, but not seeing any with optical out, only in?
Joe Fernand
AVForums Sponsor
Downmix - can def have an impact on the quality of the stereo signal you are listening too.
Source HDMI > TV > Optical > Amp - is used by many folk - though still requires your Source does a decent job of down-mixing surround sound to stereo if your content is surround sound encoded.
USB DAC - there is a huge market out there, you can spend $10 or £10k.
Just one of many -https://www.avforums.com/reviews/ifi-audio-zen-dac-review.17835
Joe
acgingersnaps
Something like a Topping D30 should work well here. Optical in for the TV. USB in for the PC. RCA connection to the amp.
Joe Fernand
AVForums Sponsor
‘I might be confused how these work or I'm looking at the wrong product, but not seeing any with optical out, only in?’ - DAC (Digital to Analogue Converter) has Digital (USB, Optical, Coax...) Input and Analogue (RCA or XLR) Output and bypasses the Digital Input/DAC in the Amp.
Joe
Madao
Most of it is DTS-HD Master Audio so I would think is my only option short of investing in a surround setup? (Not going to happen, unfortunately)
What about the E30? Amazon product
Looks fairly affordable. I wouldn't mind buying it if it was respectable enough.
acgingersnaps
Sure. No experience of it myself, but apparently it's an improvement.
Latest News
PrimaLuna debuts Evo 300 Hybrid integrated amplifier
  • By Andy Bassett
  • Published
Astell&Kern announces AK ZERO1 in ear monitor
  • By Andy Bassett
  • Published
McIntosh launches MI1250 power amplifier
  • By Andy Bassett
  • Published
AVForums Podcast: 13th October 2021
  • By Phil Hinton
  • Published
Vestel launches Red Bull TV app on European smart TVs
  • By Andy Bassett
  • Published
