Is it true that Oled TVs tend to look artifical and cartoonish?
Hank Hill
On many threads, I have heard that OLED TVs especially LG, tend to look fake and cartoonish similar to an LCD; including the notion that movies don't look like movies. However, I did read a few reviews that suggested the Panasonic GZ OLED series has a more organic and filmic look that is similar to a Plasma.
Is there any truth to those rumors?
SyStemDeMoN
No.
Russ_64
Nope, my OLED which is a Panasonic GZ looks more natural (some may say softer) picture compared to LED.
Hank Hill
According to a Youtuber named Patrik Gardewall, The Pioneer Kuro destroys any OLED in nearly every capacity and that it resembles 'a moving window of reality' However, he seems to contradict himself because in one post, he said his GZ950 is the closest modern TV to a Plasma.
But in a separate post, he said it is a 'garbage' TV thank to its flat image and diluted colors; unlike an OLED, the Kuro looks 3D without it being 3D.
Hank Hill
Patrik Gardewall is talking out of his arse.
patrik even posted a video comparison between an OLED in HDR vs Pioneer Kuro; not surprisingly that he gave the crown to the Kuro because in his words, OLEDs resemble an LCD with its cartoonist colors and lack of dimensionality.
tunnacliffe
I'm going to be upgrading from a 60" Kuro to a 65C9 so hopefully it's a nice visual upgrade :D Although I'll still be running 1080p max due to shocking internet where I live.
generalgizmo
Thing is the krp500m he would be using is not the standard pioneer kuro that most have..
Not sure whether you know or not but the kuros can be voltage tweaked to drop the black levels.. and hes done a host of other tweaks to that panel too.. I've done this with all of mine I also had a krp500 which was the best picture I had ever seen but went bigger.. cut a long story short I sold the krp600 and have had a Panasonic ez952 OLED for a yr and a half which only gets used for movies, bluray 1080p and 4khdr discs the odd film from Netflix once in a blue moon... I got the Panasonic at the time because with all the max frame other features off and in a pro mode it behaved like my kuros cinematic not at all flat and very lifelike and also the fact Panasonic then had the crown for plasma after the kuro I think they must have put some of that processing into the image...I love my kuros as still have one in the front room for everyday viewing 11yrs old from new and it's been great.. some poorer bluray transfers look better on that than the OLED probably because more detail brings out more artifacts the kuro softer image.. and good 1080p blurays are very close but it's the 4khdr movies it cant compete.. also watching a comparison is hard unless you're there really.. bit like auditioning speakers and listening from the TV or on the phone.. the kuro is a great TV build quality etc and all rounder and was way ahead of it's time but it wont last forever and I think it has been surpassed but no tech is perfect, kuros heat , energy hungry and can buzz the OLEDs like many modern leds qled can be a panel lottery too banding tint etc.. I've seen this once since I've had my TV.. will it last as long as my kuro..?? I doubt it but it's a step up in pic quality..
computershack
The simple fact is that any TV can be made to look fake and cartoonish and often with the standard settings with the image processing on it doesn't help, especially if de-judder and de-blur are in effect. I can't stand the "Standard" mode setting not only on my LG but any TV.
Hank Hill
Apparently even when the LG OLED has been calibrated, it still resembles an LCD with cartoonish like smear to its colors. Others have specified that an OLED will never be reference quality because of its WRGB which dilutes colors.
However, that Patrik guy did say that the GZ series impressed him when it came to motion handling and that it even rivaled his precious Kuro. Talking of motion, he did say both Panny and Sony's BFI modes were useless and that they did nothing to increase motion resolution.
Hank Hill
Somethings definitely haven’t improved: They look like that on my Kuro!
I heard the OLEDs look fake like an LCD unlike a Plasma with its natural imagery thank to the Kuro utilizing real RGB phosphorus that emits a natural glow to its colors unlike the artificial light that you supposedly see with OLED.
Patrik has mentioned that an OLED and a LCD are the same technology; it is still a sample and hold and use a plastic screen which ruins PQ unlike Glass.
lgans316
You are hearing way too many wrong things.
Don't believe in Fake news.
Hank Hill
I don't if anyone can refute this but here is a quote about why Plasma is supposedly the only tv that can generate such a natural and reference grade image.
*To make it easier to understand here is the Real reason Plasma tvs and KUROs looks more natural compared to todays tvs Plasma tvs have light that comes from glowing material while todays tvs have artificially created non glowing LED light.(thats the main reason) Reason why colors looks better on an Plasma tv is the same as when you compare the light from incandescent bulbs and LED lamps. Light from glowing material always renders colors better because the light spectrum covers a larger area of what we sees and it also have higher energy which gives colors an contrast boost. Only tvs that have light coming from glowing material can be classed as Reference tvs. No tvs today are black body emitters like CRT and Plasma tvs and therefore not reference. (it doesnt matter how close colors are to reference in the CIE chart its the light that is the problem) Todays LED light based tvs outputs what you can call compressed light and cuts like MP3 files important light and radiation/spectra energy. that gives colors an diffuse/flat look with light leak as whe see it."
Bl4ckGryph0n
Look a Kuro was an awesome TV. I know I had one, and if I could buy one today that support 4K I would. But you can't. So it is utterly pointless living in the past.
Since then I've had Samsung Plasma (couldn't buy a Pioneer anymore), and for the last three years an OLED from LG.
You really got to stop listening to youtubers who just generate clickbait videos which make them money ;) It is an unregulated sector and they just do stuff to get viewers. There is clearly no point in telling you that it is not true. So go out of your home, and go into a shop where the screens are setup properly. Have a look. You'll see it is not cartoonish.
Hank Hill
I doubt that Patrik makes any money from getting clicks because you need a certain amount of subs. Besides his titles ain't really clickbait unlike a certain Samsung fanboy who claims to be a Pro Calibrator.
Bl4ckGryph0n
Go buy a Kuro then ;) Oh wait you can’t.
Bl4ckGryph0n
Except you can but we were not talking about me wanting a kuro was we?
Not a new one. Nor one that supports 4K.
So why keep on bringing it into the conversation if you have no interest in one? Perhaps also take a look at some of the reviews on here from well respected people out of the industry utilising proper testing methodologies.
Hank Hill
Except you originally said the Kuro was no longer available to buy; no mention of the words 'new' and '4K' so you don't get to change the goal posts. Besides we are getting further off track when this is supposed to be a discussion about the OLED.
strangequark
From Phil's review of the GZ1500:
Plus, the engineers at Panasonic have also managed to dial out the inherent cyan blue whites of WRGB OLED and given this OLED a redder, richer colour of white which makes a big difference to image accuracy. While it wasn’t as big a standout as our hands-on with the GZ2000 recently, the correct colour of white and lack of the cyan tint (that is present even on correctly calibrated OLEDs) is not present here with viewing material. This adds to the accuracy of skin tones and colours as the greyscale is excellent.
I replaced my Pioneer LX5090 with a Panasonic FZ802, calibrated the FZ802, and I still think my calibrated LX5090 puts out a more natural picture.
I didn't return my FZ802 because the size increase is sure as hell nice (65" vs 50"), but I would have if they were the same size.
gibbsy
Is that the Royal 'we'?
Never trust a reviewer that cannot spell colour.
I've gone from a Panasonic VT plasma to a Panny FZ OLED. I prefer the OLED. No TV is perfect and the VT had it's problems.
lgans316
Probably ranks amongst the top 5 childish thread created in 2019. Feels like swimming deep inside Quantum Apotheosis YouTube channel.
Hank Hill
Why is making a thread about whether OLED looks artificial like an LCD...childish?
Similar threads
Trending threads
Latest news
Apple TV app now available on Roku devices
  • By Andy Bassett
  • Published
Sony announces 360 Reality Audio tracks available in Autumn
  • By Andy Bassett
  • Published
Google Stadia and Pixel Buds launch dates announced
  • By Andy Bassett
  • Published
Pixel 4 and 4 XL smartphones launched at Google event
  • By Andy Bassett
  • Published
