is it this easy?
Discussion in 'Subwoofers' started by Dr Pumpstain, Sep 23, 2004.
  1. Dr Pumpstain
    Dr Pumpstain
    I have a home theatre system (Sony DAVS880) but am unhappy with the bass level from the Sub even when turned up full. Can I just get more bass by throwing this speaker away and getting a better one? Cheers in advance for your responses to what must be a stupid question...it's can't be that simple...can it?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I would say witout knowing the way the sub was connected to the amp or if the amp is in the sub it might be possible to substitute the sony sub for a better one .
  3. Dr Pumpstain
    Dr Pumpstain
    the speaker cable plugs into the back of the dvd player via a socket and the wire at the speaker end is just wirewhich goes into the usual red and black springy clips that you see on loads of speakers. Will this work?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    So your saying all the speakers connect to the dvd inc the sub. If this is correct then yes it would be possible to buy a sub with high level inputs (speaker connections) and connect directly to the dvd player for more/better bass. :D
  5. Dr Pumpstain
    Dr Pumpstain
    that's good news, thanks for your help, after just purchasing my first projector I will start looking for a new Sub...I think I'm addicted to spending money.
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Does the Sony connect to the sub with standard speaker wire or a phono cable?
  7. Dr Pumpstain
    Dr Pumpstain
    standard speaker cable. would I need an active sub???
  8. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    youd need an active sub.
  9. Dr Pumpstain
    Dr Pumpstain
    great, thanks for your help.
