Is it safe to turn a RP TV on it's side?
I
I J S
I need to manoeuvre my Toshiba 46" set around a very tight corner at the top of a flight of stairs and the (seemingly) easiest way of doing this would be to turn it 90 degrees onto it's side and tease it around.However, i don't wan't to do this if all the sets innards are going to come loose or there's any risk of damaging the t.v.
Any advice would be greatly appreciated (aside from knocking walls through)!
S
shaunthedude
it should be fine as long as its not knocked or bumped. i had mine on all sorts of angles to get it in. erm the tv that is.
hth
shaun
