Is It Possible to Upgrade HDD in DVDR??
Discussion in 'Blu-ray & DVD Players & Recorders' started by pshankland, Dec 10, 2004.
  1. pshankland
    pshankland
    I am just about to buy a Pioneer DVR-420HS which comes with an 80Gb HDD but I was wondering - is it possible to upgrade the HDD in DVD Recorders?
    Obviously this would be really good as the price of a large HDD is cheaper than going for the higher capacity DVD Recorder.
    Thanks.
    Pete.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    No - all current HDD/DVDRs are firmware locked to prevent HDD upgrades. On some models you can change the drive - even for one of an increased capacity - but only the original amount of space is recognised.
  3. TobyW
    TobyW
    Jan 6, 2005
    157
    Australia
    +3
    I tried changing my Tosh XS32 (80GB) to a 120GB drive, just to see what happened. The answer: it displayed Error Code 7034 and locked out all the controls. (RISK OF ELECTROCUTION - DO NOT TRY THIS YOURSELF!)
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    What drive were you using? I suppose some effort should be made to try and compile a list of 'working drives' and advice on upgrading.
