Is it possible to link a DVD player to two amps?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by rudy, Mar 23, 2005.
  1. rudy
    rudy
    Jan 2, 2005
    499
    I want to put an av amp in 1 room and music in two seperate rooms off 1 source.
    Any advice?
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Look for an amp that has "Zone 2" facilities.
  3. rudy
    rudy
    Jan 2, 2005
    499
    Zone 2 ??? Me novice, you expert!
    Thanks for help, that could be just what i need.
    Can i get one of these for under 400 quid?
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    You will have lots of options.
    Something like this, could be used as a starting point
    http://www1.shopping.com/xPF-Yamaha_RX_V650
    But Marantz, Denon, & Pioneer (and other), have models in your price range. Then there are 2nd hand ex-flagship models that are also candidates.
  5. rudy
    rudy
    Jan 2, 2005
    499
    Thanks Harry
  6. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    My pleasure. Hope it solves your situation.
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,370
    United Kingdom
    +1,733
    Some amps will only output an analog signal to Zone 2, so watch out for that.
    Another option if you already have two amps is just connect the dvd player via both digital outputs e.g one amp connected via optical, the other via digital coaxial. Most dvd players will have both optical and coaxial outputs.
    If one of your amps doesn't have a digital input then you could connect to it via a pair of analog phono cables.
