Is it possible to get Component/RGB signal from Sky Digibox?
Discussion in 'Projectors, Screens & Video Processors' started by Dwayneburke, May 21, 2004.
  1. Dwayneburke
    Dwayneburke
    Are there any devices i can use to run my sky digibox (not SKY+) and run it with decent signal to my projector as the composite is just not doing it
    Do sky+ plus offer any facility for this?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Sky digiboxes all output RGBs (R, G, B plus sync on composite video). A JS Tech RGB to YUV converter will turn this into component to connect to your projector (some projectors also work with the RGB to VGA box). Some (but not many) of the latest projectors now have a sync connector alongside one of the component inputs so that all you need to do is run a scart to 4 phono cable...
    Sky+ is the same, but also has an s-video output (as do a limited number of Grundig plan Sky digiboxes) which is a quick and easy improvement over composite.
  3. sapgem
    sapgem
    Dec 11, 2002
    83
    Liam,
    Which of the new projectors are able to accept RGB this way? Would make connecting Sky+ a whole lot easier.
    cheers
    gareth
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    I wouldn't say it's something you should let swing your decision one way or another but from the top of my head Sim2, ProjectionDesign, Mitsubishi HC2000, Sharp Z12000 etc all have sync connections. Sanyo Z2, infocus X1 NEC HT1100, and quite a few others can accept RGBs from their VGA sockets (requiring an appropriately wired scart to VGA adaptor)
