Is it possible to get an indoor dish?..or what're the other options for ppl in flats?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by oreoboy13, Mar 31, 2002.
  1. oreoboy13
    oreoboy13
    basically just that, i would like to get SKY+, however i live on the 3rd floor in a block of flats. I thought about an in door dish as in my lounge, one corner is floor to ceiling glass and then about 7ft in along both walls.
    Any help would be great.
  2. oreoboy13
    oreoboy13
  3. bob007
    bob007
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You can have an indoor dish but it will need to be bigger than a minidish since the glass will absorb some of the microwaves.
    Also SKY will not get involved with that sort of installation so you'll have to buy SKY+ yourself and make other arrangments with an indpendent specialist. That means an expensive job:(
    Basically it's possible not just practical if you live in a flat.
