is it possible to biwire the front main speakers on denon 3802
Discussion in 'AV Receivers & Amplifiers' started by mick23, Apr 3, 2002.
Tags:
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    on my 3802 i am using (a) for pair of surrounds and a pair of rear speakers can i biwire the front main speakers i was told a can run 2 pairs of cables to the the front speaker terminals but i am a bit concerned in trying this thank you
  2. bob007
    bob007
    I had a pair of M73's by-wired a while ago, no problem.
  3. rnjones
    rnjones
    Mick this shouldnt be a problem. I have Mission 753s bi wired from my AVC-A11SR. Basically at the speaker end you bi wire (leaving off the connector between the posts on the speaker) and connect both + (red) wires and both - (black) wires at the 3802 end. I made a mistake once of reversing some cables and high and low ranges were out of phase. Very strange sound.
    Otherwise I cant think of a reason not to do this.
    Rog
