Is it possible to activate AV4 in 32fx66?
Discussion in 'General TV Discussions Forum' started by mandingo, Jan 24, 2003.
  1. mandingo
    mandingo
    I mean, it has 3 rear scarts and 1 side s-video in... can you use all 4 inputs?
    Excuse me if it appears in the manual, but I still don't have the set (and still wondering if I should buy this or the philips 32pw6506).
    Thanks and best regards,
    mandingo
  2. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    I have just got this set & AV4 is enabled.
    I'm using the 3 scarts but did use the side composite(?) input (AV4) but haven't tried the s-video yet.
  3. mandingo
    mandingo
    Cool!
    Yeah, I meant s-video or composite, I thought that input was the same as scart 3 (s-video one), and I wanted to use 4 different sources.
    Well, one more reason to get this set :p
    A lot of thanks and regards,
    mandingo
  4. MattDX
    MattDX
    ah but can you use the S-VHS and composite sockets for different hook ups at the same time giving you a 5th AV as it were?
