Is it possble to get S-Video & digital audio out of an X-Box?
Discussion in 'Nintendo Forums' started by AVmaster, Jan 23, 2005.
  1. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    As title.
    The best video connection my amp has is S-Video which I am feeding via a 10 metre S-Video lead to a ceiling mounted projector (better S-Video than composite), but I will also need a digital output from the X-Box for proper 5.1 surround sound, otherwise I will have to use a 2 channel audio phono connection and use DPL2 on the amp instead :rolleyes:
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Thanks mate, I can see some on Ebay now :)
    What's the deal with getting HD out of the X-Box by the way? Is it a case of just using a HD game and a Component connection?
  4. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    520
    North Cotswolds
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    Hidef can only be enabled when the xbox has been modded (softmod/modchip), this allows you to region switch the xbox (make the xbox think it is american!!!! Poor thing.... :p :p :p). When it thinks it is american then you can run a progressive component signal out of the xbox, drastically improving the picture quality.
  6. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Thanks for the info on the lead Gag, I ordered it from them via PayPal :)
    Regarding Hi Def again, does the box upscale from 480/576 to a Hi Def resolution then?
  7. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    A modified xbox allows games to run in hidef widescreen formats. These are 480p 720p and 1080i. The resolution you get depends on the game. Comparing hidef component Halo 2 and scart Halo 2 was a no-brainer. The component connection will make the picture look much better, even if the reolution isnt much higher.
    Thats not to say its bad though! Far from it, I would still be happy to play on Svideo/scart I think.
  8. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    I'll stick with the S-video lead that's running above the ceiling then :)
  9. fabbers
    fabbers
    May 19, 2004
    128
    +10
  10. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Are you sure? It says digital on the website and i've ordered it now :eek:
  11. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    according to that site and to the picture, the official one does have optical out....
  12. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    It arrived through the post today and it does indeed have an SP-Dif socket, but it also has a sticker on the packaging saying"Enhanced NTSC S-Video AV Pack (US, Japan)". Hopefully this means that it is not for NTSC use only as my X-Box is an un-modded region 2.
  13. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    520
    North Cotswolds
    Don't worry about it. I bought this exact lead before I modded my XBox and PAL seems to work perfectly. My lead also reads NTSC; must be an import.
    I think I spent more money on the Optical and SVideo leads :rolleyes:
