Is it poss to iron out a ripple?
Discussion in 'Projectors, Screens & Video Processors' started by emporer, Aug 9, 2005.
  1. emporer
    emporer
    Mar 10, 2005
    8,221
    +1,626
    Have a pulldown 70 inch da-lite jobby with a small ripple either side at the bottom, opnly really noticeable when footy is on, I was thinking about ironing it out. Is this a possibility/solution or will I just bugger the screen up? If I pull gently on either side of the screen then the ripples go so I may end up making a small brace to do this.
    Any sugggestions welcome
  2. shahedz
    shahedz
    Apr 26, 2005
    10,826
    +1,718
    i would not know about ironing, but have you considered steaming first? maybe you should try this first? i have never tried it, but a lot of irons have the option and it used to take out ripples. but as i have never treid it i cant confidently recommend it
  3. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    could you try sticking some stiff card around 6 inch square to the reverse of the screen, where the ripple occurrs
