Is it posible to match Missions with Pioneer???
Discussion in 'AV Receivers & Amplifiers' started by WBC, Mar 6, 2005.
Tags:
  1. WBC
    WBC
    Guys,
    I have an 811 Amp. It's currently matched to a mission mixup (as seen below) M74i's Fronts with Ixos Speaker Cable. I think, in all, the sound is far too bright!!
    I've been looking at the Castle's sats but can't get a demo. I've since seen the Mission M30's (which are more friendly to my budget and have more than acceptabe WAF) but don't want too throw good money after bad and I wasn't Impressed with the 74i's.
    If I put the M30's with a XLS sub do you think the Pioneer will compliment them???? Is it even the amp??? Should I be looking at a completely different Speaker Manufacturer or should I consider changing the wire? OR will it match?
    I'm sure its boring but I need an experienced opinion!!!!! :lesson: :lease:
    Stace :D
  2. Upgrade King
    Upgrade King
    Aug 8, 2004
    16
    If you buy the Castle compacts you will not be disappointed - they sound far bigger than their size sugests - as for sound, smooth sublime and very musical, they will also take and sound better with upgraded amplification.
