Is it OK to use 2 6ohm speakers as rear surrounds when the rest are 8ohm?
Discussion in 'AV Receivers & Amplifiers' started by pez, Sep 9, 2004.
Thread Status:
Not open for further replies.
  1. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    the denon 2805 is driving the evo 3b 5.1 ive recently bought well (even the sub, which appears to have a problem...see the subs section).
    I went out today and bought some proper QED Micro and Original speaker wire to wire everything up, and was planning on picking up another set of EVO 1s for rear surrounds this weekend.
    in the meantime ive got some ok sony 6ohm 80 watt rated speakers lying around.
    can i connect those up to the denon amp (rated at 100w per speaker) even though the rest of the EVOs are all 8ohm and rated at over 100w?
    also, should the test tone and the auto setup of the denon amp be so loud?
    I thought it was broken the first time i ran it!
    pez
  2. Arcangel
    Arcangel
    Yes. It will be fine with those speakers. The test tones are loud as the volume usually sets itself to 0db when they're run. Once set, 0db would equate to Reference Level for playback. :)
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
Thread Status:
