Is it ok to join Coax cable?
Discussion in 'Cables & Switches' started by hamd01, Jun 8, 2005.
  1. hamd01
    hamd01
    Mar 21, 2005
    947
    46
    Cumbria
    +127
    I have just bought a new digital areial, along with 10m of cable. Typically the cable is too short, and I need to add 5m to it. Is it ok to join two coax cables together or am i going to loose signal strength?
    I was thinking about putting a male on one cable and a female on the other, and plugging them together.... is that the best way to join them?
    Thanks in advance
    David
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Not ideal as you probably know but as long as you terminate the leads well then I can't imagine it being a problem. :)
  3. hamd01
    hamd01
    Mar 21, 2005
    947
    46
    Cumbria
    +127
    For fear of sounding incredibly stupid..... terminate the leads??
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Putting the connectors on the ends is known as terminating. They are terminals after all. :)
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    just solder the 2 lengths of wire together
  6. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    Wouldn't it be almost as cheap, probably easier, and certainly better quality, to just buy 15m of cable rather than 5, and then have one run all the way?
  7. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    That would be the better option indeed.
