Is it normal?
Discussion in 'General TV Discussions Forum' started by spocktra, Dec 1, 2004.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Only just entered the 100htz club.Is it normal to see varying amounts of screen noise on some broadcasts through sky?.My signal strength and quality are what seem to be only approx 65%.Would this make a noteable difference.I recently changed a pd30 for a zp48 and although a lot better sometimes its not as good as my old sony[50htz].
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Any thoughts on this anyone?
  3. Goggleyes
    Goggleyes
    Nov 16, 2004
    40
    I have Freeview and the bitrate/quality of transmissions can vary dramatically from programme to programme. Sky is probably the same.
    The digital artifacts visible with low quality broadcasts can indeed become more obvious on 100Hz sets, so you may have to adjust the scannnig mode of your TV to best suite the broadcast.
  4. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Cheers that has set my mind at rest,it seems that 100htz ,when its good its superb, when its bad its very bad.
