Is it normal to hear a bit of static when turning up volume knob on amplifier?
Discussion in 'Home Cinema Buying & Building' started by Trillion777, Jun 28, 2015.
  1. Trillion777
    Trillion777
    Jun 26, 2015
    4
    Liverpool
    Hi, I recently purchased a Marantz PM6005 amplifier and I've noticed that if I turn the volume knob up when my optical cable is connected from my PC to the amp, and no sound is playing, I can hear a little bit of static noise through the speakers/headphones. This effect is far less apparent with my Fiio E10K connected via 3.5mm line out to RCA, but this route seems to amplify the sound less anyway. Seems that all sound is about 80% of the volume this way.
    Is this normal?
  2. brindleness
    brindleness
    Jul 18, 2015
    3
    York, UK
    I get this on my setup and just assumed it's normal. I wouldn't worry too much. As long as it all works, jobs a good un'.
