Is It My Speakers Or My Denon Amp
Discussion in 'AV Receivers & Amplifiers' started by roberte, Mar 10, 2005.
Tags:
  1. roberte
    roberte
    Nov 14, 2004
    177
    +10
    WONDERING IF A GIFTED TECHIE WOULD HELP ME :thumbsup:
    IM GETTING A SAFETY SHUT DOWN QUITE REGULARILY ON MY DENON1601
    AMP,AND CANT UNDERSTAND WHY
    IF ALL THE SETTTINGS ARE AT DEFAULT I CANT GET ABOVE -15DB VOLUME ON A FILM LIKE MASTER AND COMMANDER BEFORE I GET SHUTDOWN ON THE
    BATTLESCENES ,MY SPEAKERS ARE
    CENTRE MISSION MC7 8 OHM
    FRONT SPEAKERS OLD MORDAUNT SHORTS 8 OHM
    REARS OLD TECHNICS 8 OHM
    THE SYSTEM WOULD STILL SHUT DOWN IF MY REARS ARE NOT WIRED IN
    PLEASE COULD ANY BODY HELP ME WOULD BE V GRATEFUL,THESE FORUMS WERE VERY HELPFUL WITH REGARD TO LCD SCREENS SO IM SURE THIS SECTION WILL BE AS HELPFUL
    P.S
    HEAT BUILD UP NOT AN ISSUE AS THE AMP IS CLEAR FOR VENTILATION
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    It could be that the large amount of bass in such films are demanding too much from your amp, try turinng all your speakers to small on the amp if you have the option and replaying the scene.
    If the problem persists then look for crossed/touching wires on both speaker and amp end. Just check the obvious, and then take all the connections out (so the amp is as bare as it would be new) and put them in one at a time, i.e. front speakers and a source. Play some material and build it up At the point when the system fails thats probably the culprit. If the problem is still ocurring and either it doesn't seem to be any of the components or it happens if you only have the front speakers, amp and dvd player in then it's probably the amp, as its less likely the speakers are broken.
  3. roberte
    roberte
    Nov 14, 2004
    177
    +10
    thanks for advice will try
