Is it bettter to re-direct the bass frequencies from the main speakers to the sub?
Discussion in 'AV Receivers & Amplifiers' started by pavlos, Mar 12, 2001.
  1. pavlos
    pavlos
    Mar 5, 2001
    11
    I was told that is better to redirect the bass frequencies from the main speakers to the subwoofer cos sometimes DVDS can have so low bass frequencies that the main speakers cannot cope and if that is the case should I re-direct the bass frequencies from my surrounds too?
    thanks in advance
    pavlos
  2. CarlB
    CarlB
    Jan 8, 2001
    1,303
    Cambridgeshire
    +227
    It depends on the response of your main speakers. In most setups the answer would be 'yes', it is for me - I have my receiver set to 'small' speakers all round, which routes everything below 80Hz to my sub. My speakers claim to go as low as 55Hz, but as they are only bookshelf models (Tannoy M1) their output rolls off dramatically at lower frequencies.
    I experimented with both 'large' and 'small' settings, including wiring at both high and line level simultaneously to my REL sub, but I have settled for line level output and 'small' speaker settings as I feel this gives the best results for me.
    If your speakers can cope with low frequency (with little loss of output) then go 'large', otherwise you'll probably be better served by bass redirection.
  3. Guest
    Knowing what speakers you have would be useful.
    I have KEF Reference Model Fours, which go down very low. Switching them to Small on my processor and re-directing the Low Frequencies transforms the sound (for Movies) you will get much more detail, steering will sound more dramatic, more pings and tings all round really.
  4. pavlos
    pavlos
    Mar 5, 2001
    11
    well my main speakers are the Jamo E870 , looking at their specifications they start from 50hz, what do you think I should do, the point I was trying to make is that I was told by a few people that even if my main speakers go low enough still will be be better to redirect the bass freq. to the subwoofer..and then what about my surround speakers they are part of the E870 Jamo package , should they be re-direct too? by the way my main speakers are bi-wired to my sony 940 receiver and my dvd player is the pioneer 636D.
    Thanks in advance
    pavlos
  5. HT Dude
    HT Dude
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Don't know how to link it here, but check out the long thread started by Duncan Wardle a month or two ago.
    We all got stuck in and came to simple conclusion, route all LFE to sub, ie, 80Hz and below. It is more than worth it.
    Use search to get the post.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  7. Mikael
    Mikael
    I also agree you should probably re-direct to your sub. If I recall correctly, the Sony 940 allows you to specify the re-direct frequency separately for front, center and surround, so if your fronts go down to around 50, set it to redirect from 60 or 80 Hz, and perhaps even higher for the surrounds (assuming they are smaller...)
    My Sony 925 redirects at 100 Hz, and I have largish floorstanders all round, but I have found they sound better as small.
    /Mikael
    No! Try not. Do... or do not. There is no try.
  8. pavlos
    pavlos
    Mar 5, 2001
    11
    ok guys thanks for your responces,last question, assuming that I re-direct the bass frequencies from my main speakers and my surround ones to the sub what is appropriate cut-off frequency I should put on my sub, it goes from 50hz to 150hz and also there is phase control as well, can you let me know its use and lastly when I redirect the bass freq ie choose the small setting on my reciever that means that ALL bass frequencies will go the sub woofer or from a certain range?
    Thanks in advance
    pavlos
  9. Spaceman
    Spaceman
    pavlos, you can just set the subs filter to it's maximum (150) since your amp won't put out much above 80Hz. If you set the filter to, say, 40Hz then you'll have a gap between 40Hz and 80Hz (the receiver's cutoff freq.).
    I have my sub connected to my mainspeakers. I do not use the sub-out. I rout the bass of my center and rears to my fronts and also the LFE signal go to my fronts. My fronts don't go below 50Hz much and then my subwoofer takes over. This works the best so far... in my opinion. But you guys probably think I'm nuts [​IMG]
