Is it best to play the 360 on 1080i
Discussion in 'Xbox Forums' started by nigel2shady, Dec 28, 2006.
  1. nigel2shady
    nigel2shady
    Jun 4, 2006
    734
    +9
    Sorry but I am new to all this just got my xbox today and just hooked it up to my hdtv,should I play my games at 1080i or should I play at the 700 or 400 setting and wot is the difference...
    Thanks for your help in advance...Have it at 1080i at moment
  2. dave1de
    dave1de
    Nov 16, 2004
    2,168
    48
    +33
    1080i = high defininition
    720p = high defininition
    480p = standard definition
    Very little difference between 1080i and 720p, just depends on your tv set really, try experimenting with both and see which you prefer
  3. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    I would agree with the above,
    As you have HDTV, stay away from 480p as it won't do your 360 justice.
    Whether to plump for 720p or 1080i really does depend on the TV.
    Try both and see which one you like best (although you may not notice much difference)
    My previous Sharp 32'' LCD definitely displayed a better picture with 720. However, i currently have a 42'' Hitachi plasma and it likes 1080i much better.
    Hope this helps...
  4. Mattk84
    Mattk84
    Feb 20, 2006
    3,547
    Weymouth,Dorset
    +135
    Dobie,love the family guy quote !
  5. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,393
    +850
    Set the console to the native display of your panel.
  6. CAFCmatt
    CAFCmatt
    I have a 32" Samsung and to be hnest I notice very little difference between 720p and 1080i.
    Use 1080i though
  7. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    I would have thought if theres very little in it that 720 would be better for being progressive scan, thus no interlacing taking place?
  8. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I have used both 720p and 1080i and my eyes seen to find 1080i a little bit better only on the dash board. No big difference via games.
  9. Markoos
    Markoos
    Mar 13, 2006
    1,566
    48
    Preston
    +95
    Using a 27" Bush HD LCD and 1080i looks a little nicer to me. Not a massive difference, but a bit smoother round the edges.
  10. dvdric
    dvdric
    Apr 6, 2002
    243
    ENGLAND
    +4
    I used to use 720p on my samsung 26inch. but since i got my HD-DVD drive i only use 1080i now.:)
  11. onesandtwos
    onesandtwos
    Jan 10, 2006
    96
    Wrexham
    if the native resolution of your TV is 720 then go for 720 as almost all xbox games render in this resolution and there won't be any scaling at all...
    If your screen is one of the new fangled 1080P screens then it might be best to go with 1080I although this will cut your framerate down by half (from 60fps to 30fps)... try both in this case and see which upscales best, your xbox or the TV....
