Is HS10 HDCP compliant?
Discussion in 'Projectors, Screens & Video Processors' started by robfitzp, Nov 13, 2003.
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Thinking of getting a Pioneer 868 (and HDMI/DVI adaptor) but no idea if the HS10 accepts a HDCP signal?
    Rob
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Yes
  3. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Thanks!
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  7. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Gordon,
    Probably a good idea.......
    Rob.
  8. Kramer
    Kramer
    2 years :confused:
    HS10 was first released in Japan barely a year ago ;)
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    :blush: 1 year yes got my calc wron(it's all these threads you keep starting ;)) but still don't think it is HDCP aware, though I hope it is, 20 is but 10......
  10. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    did anyone ever get a definite answer to this question?
    ie:did they actually get an hs10 to work with the pioneer 868 dvd player via hdmi-dvi connection?
    really anxious to know as i am considering purchasing the pioneer 868 dvd player to go with my hs10 and want to use the full capabilities of the dvd player.
    many many thanks in advance
    paul1672
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
  12. martinsurround
    martinsurround
    Hi Guy:
    I don't think HS10 accepts the HDPC DVI connection.
  13. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    again,i get conflicting answers.
    boy this is hard.
    i just dont want to make the mistake of purchasing an expensive dvd player only to find it wont do what i want it to do.
    is there a cheaper dvi alternative that will give me just as good results but will definately work with the hs10???
  14. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    right,i've done some searching and came across this paragraph:
    VPL-HS10 CINEZA LCD Front Projector
    The Sony VPL-HS10 offers brilliant performance and can be used on a tabletop or ceiling mounted for screen size of 40- to 300-inches. It incorporates a Wide XGA LCD panel with 1366 x 768 resolution, 1200 ANSI lumens and a 700:1 contrast ratio.
    In addition to its outstanding contrast ratio, the VPL-HS10 projector incorporates CineMotion reverse 3:2 pull-down technology, and a DVI-HDTV connection that enables copy-protected, high-definition video content to be delivered from a DVI/HDCP (High-bandwidth Digital Content Protection) compatible set-top box, such as Sony's SAT-HD200 HD/DIRECTV receiver.
    so,am i now understanding this correctly in thinking the hs-10 is hdcp compliant????
    i really do hope so....
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    You're right that It's DVI/HDCP compliant, which means that an HDMI-equipped DVD player SHOULD be able to talk to it. If you take a look at that link I posted you'll see that not all cases of HDMI->DVI/HDCP work, though as I noted before someone posted there to say the 868 did work with the HS10.
    It'd be interesting to know what information martinsurround has that makes him think it doesn't.
  16. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    oh well,i guess i'll soon see.
    i've decided to take the plunge anyway as i'll be upgrading the hs10 within a year anyway.
    if it don't work i'll just resort to using component.
    thanks anyway.
    now got fingers and legs crossed
    paul1672
  17. Kramer
    Kramer
    IIRC there were problems with early HS10s & HDCP compliance. Sony fitted replacement boards to affected HS10s.........
    Think it was detailed in a Sony service update (.pdf) which I may have saved somewhere.
    Will have a search for it.
    :smoke:
  18. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    oh dear
    and knowing my luck i have one of the early ones.....
    i think it was bought in feb 2003....
    oh well,like i said,i'll soon find out.
    many thanks for all the info guys
    paul1672
  19. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    well,a few months back i made the purchase of a pioneer 868 hdmi dvd player and connected it the hs10 and true enough my hs10 was hdcp enabled as i had a mighty fine picture displayed from my hs10....
    since then though i've moved on to purchase the hs50 but i just thought i'd post my findings here to help some people out as i've had a few pm's now asking if i had any success.
    hope this helps people out.
    by the way,this is only my experience in the matter so please dont assume all hs10's are ok just on my findings.
    all the best
    paul
