Is gamecube SVHS compatible
Discussion in 'General Video Gaming Chat' started by lilly, Mar 16, 2003.
  1. lilly
    lilly
    I just bought a Gamecube for 79.99 with luigi and a memory card from Argos, then bought a madcatz SVHS lead which will not work with the gamecube but works fine with my N64.
    Is there a problem with my gamecube or does it not output SVHS as in the manual it only mentions video out and RGB out
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    The PAL version Gamecube does not output S-Video so you will have to use, RGB Scart, Component Video or Composite Video :).
  3. lilly
    lilly
    Thanks for that i'll get a RGB cable instead.
  4. russraff
    russraff
    Aug 1, 2000
    2,413
    Newcastle
    +63
    Please excuse my ignorance, but where can you get a Gamecube component cable? I have done a moderate amount of searching, but can't find one.
    Russell
  5. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    They are not available in the UK High Steet. Nintendo only released the Component Cable in the US and Japan. You can import one quite easily. Choose from one of the following:
    http://www.ncsx.com
    http://www.tronixweb.com
    http://www.lik-sang.com
  6. russraff
    russraff
    Aug 1, 2000
    2,413
    Newcastle
    +63
    God! That must be the quickest reply in the history of the forums!
    Does this mean that you need an imported 'cube, or will these cables work with UK spec machines?
    Russell
  7. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I've seen quicker :laugh:.
    You don't need an import Cube - the PAL Cube supports Component Video output in the exact same way :).
  8. russraff
    russraff
    Aug 1, 2000
    2,413
    Newcastle
    +63
    Evidently ;)
    Thanks for the help. I may have to buy one, seeing as they are now relatively cheap. Are Argoss still the cheapest/best deal?
    Russell
  9. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    I have a £30 off voucher for a Gamecube which you can gladly have for £10, and thus save yourself £20 in the process ;). The voucher came with the GBA SP and all you have to do is send it off with your Gamecube Till receipt, and those lovely people at Nintendo send you back a cheque for £30.
  10. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Will the Big N allow the £30.00 voucher Back on a Cube which was brought at Argos for £78.99 ? ? ( I don't Think So )
    What do you think the Big N would say about the Gube / Memory
    Card & Game for £48.99 :nono:
    I Think it would Be Noooooooooooooooooooo
    Buy the way have you still got the Voucher , is so I might take it of your Hands for a Big Ben
    :smashin:
  11. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Well Nintendo would still be making money ;-)
  12. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    I know but not as much as They would Like :laugh:
    They should have made the Cube a better price to start with
    then they may have Sold more Cubes :smashin:
    But like you have said they will still make money on that Price
    :smoke:
