Is Fosgate Audionics good speaker???
Discussion in 'Home Cinema Speakers' started by ciber, Jan 9, 2004.
  1. ciber
    ciber
    FOSGATE 5-1/4" BOOKSHELF STUDIO MONITORS
    The FA51.0 is the smallest of the family, with a 5.25 inch mid/woofer and a 1 inch silk dome tweeter in a proprietary waveguide. The FA51.0's size permits it to be placed nearly anywhere, and its high output capability allows for use in front, center or rear channel applications of Dolby Pro-Logic II, Dolby Digital, THX EX, DTS, and DTS ES. This driver/enclosure design allows maximum power output balanced with accurate and detailed sound quality at any listening level.
    Features
    5/8" MDF construction, internally braced enclosure with reinforced front baffle for minimal cabinet resonance
    Utility black ash vinyl finish matches any home decor
    Slot ported enclosure for extended low frequency and improved efficiency
    1" soft dome tweeter with neodymium magnet and separate heatsink for natural sounding highs and high power handling
    Tweeter waveguide for control of high frequency dispersion
    Tweeter level switch to lower tweeter output 3dB for "live/reflective" rooms
    5.25" video shielded, oversized motor structure, mid bass driver for natural low frequency reproduction
    24dB/octave Linkwitz-Riley crossover with optical tweeter protection with notch filter for midbass protection and zobel network offers improved high frequency performance, natural sound, and great reliability
    Built in optical protection for high frequency driver
    Gold plated 5-way binding post input terminals
