Is Ellion 950s compatible with sky digital?
M
mel27
I set up my new ellion 950s dvd recorder last night but when i scanned all the tv channels into it the reception for the sky channel is pretty poor. The dvd is connected to the sky box via a scart lead.
Any advise on how i can improve this?
Thanks!
ghinzani
I got a similar thing when I set mine up yesterday- the pictures fine when watching it but when I recorded it it seemed a bit blurry - although that was the 2nd highest quality setting not the highest. Again I used scart connections.
M
mel27
Thanks for the reply
Mine is fuzzy whilst watching & it records that way too....
M
mel27
Yeh, they are inserted ok at both ends & its the same scart lead was using with previous dvd player & there was no problems with that...
Archie Fax
My guess is you need to connect the dvd recorder to the tv with a scart lead. Rf aerial type daisy chaining connections often get fuzzy results.
Have a look at the tv/ dvd-r/ skybox instruction manuals about scart type connections and recording from ect.
