Is DVD decoder trial enough or do need to pay
Discussion in 'Microsoft Windows' started by HiZ, Sep 14, 2005.
  1. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    I've installed Intervideo WinDVD again since a re-build. I remember the WinDVD application did say its expired and I needed to activate/pay but XPMCE seemed to work OK. Was this some stroke of luck or is this correct and therefore i will never have to pay even after 14 days?
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    The latest trial works for 60 days so you'll have to pay for it or find another.
  3. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    It depends on thier protection I am sure they have locked down windvd as you say you can't access it but maybe they haven't locked down the decoder being used by other apps i.e MCE so then if thats the case then yes you won have to pay.
