is DTS-ES 6.1 compatible with DTS matrix 6.1 on YAMAHA AMP ?
Discussion in 'AV Receivers & Amplifiers' started by fly6608, Oct 14, 2003.
Tags:
  1. fly6608
    fly6608
    I played the DTS-ES 6.1 encoded 'Spirited Away' with my YAMAHA RX-V340 amp, which could decode DTS matrix 6.1. the amp only generated some noise to the speakers. But this disc can be played using my friend's amp that only support DTS 5.1.
    I heard that DTS-ES 6.1 was backward compatible with DTS 5.1 by ignoring a track. But my amp treated DTS-ES 6.1 as DTS matrix 6.1, and could not decode it successfully, even I put off the 'matrix' light on the front panel using remote control.
    Could I force the normal DTS 5.1 decoder to work with disc to hear something?
    :confused: :confused:
    Please help me... thanks in advance.
  2. fly6608
    fly6608
    can DTS-ES 6.1 be decoded properly on YAMAHA amp which supports DTS 5.1 and DTS matrix 6.1?
    could anybody help me?
    thanks...
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,461
    United Kingdom
    +1,915
    DTS ES Discrete is fully compatible with DTS ES Matrix and DTS 5.1 decoders. Info here:
    http://www.dtstech.com/home&car/overview.php?ID=1026399626
    Your amp has "Phantom" DTS ES Matrix and Dolby EX processing to generate a rear centre image. Maybe you've missed something in the setup procedure but I would have thought by selecting the correct mode you should get sound from the phantom rear centre.
  4. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    I have a yamaha RX800 and the 6.1 automatically choosen.
