Is D-vhs Finished?
Discussion in 'Digital TV & Video Players & Recorders' started by charles, Mar 18, 2002.
Tags:
  1. charles
    charles
    Jul 6, 2001
    1,431
    63
    norwich
    +204
    According to Philips they are ceasing suppying their clone version of the JVC D-VHS video,and JVC themselves are "keeping supplies available for the moment",but have no plans to bring out a further model.
    This has the familiar tale of Video 2000 ,Betamax and Digital Compact Cassette about it.
    Anyone out there who knows more on this let me know. Having been a victim of DCC I do not wish to buy a D-VHS video if the format is going to end.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Some US studios have announced they will supply movies in the D-VHS format mainly intended for the US HDTV system, although it does look like a gimmick play on their part it just might encourage growth in the format. However that is of no use to the UK users so effectively the format is just going to be the ultimate tape based recording format.
    In a couple of years maybe less expect to see the DVD recorders using the new lasers to enhance capacity 10 fold compared to todays standards and with a format war behind them that is surely the way to go.
    In the short term as long as you have plenty of sealed blank tapes you can store for future use for a D-VHS machine then it will serve you well as a recording device.
  3. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Its a pity if this is the case. I record to good quality svhs tapes and get 17.15 hrs per tape in LS3 mode. I have to say the quality is awesome. It is such a pity dvhs didnt take off. As an archive device it is brilliant. You cannot tell the difference between original picture and the copy.
    One note however. Make sure you purchase an rgb to s-video converter or you will be recording abd displaying in composite mode!!
    Deks
  4. tiberious
    tiberious
    So , anyone know the best place to pick one up these days ??
    - I bought one about a year ago for £690 - if they can be had for less now, I think I`d double up !!
  5. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,348
    3
    +8,827
    This is typical of Phillips, dcc, cdi, v2000 need i say more
  6. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    Guys
    I have a JVC D-VHS deck in perfect condition which I no longer use (I've gone DVD direction). Open to offers.
    Phil
  7. tiberious
    tiberious
    philipb
    I have sent you a PM.
    CHEERS
  8. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Not sure who may have them in stock. msaybe if you do a search on www.pricerunner.co.uk or equivalent.
    The reason Phillips have stopped is because they are JVC D-dvhs recorder re-badged in a Phillips case.
    Take care
    Deks
