Mylo said:You're lucky mate, us mods have to![]()
pave said:Just seen a post about correct spelling,do you think it is important on these forums?
As for me ,i am not the greatest in the world,and often use spell check,
So just wondering...what do you think?![]()
sean5302 said:I feel quite passionately about spelling.
Imagine language were a mathematical equation.
You either get the right answer or you don't.
Right or wrong.
Some folks will think I should have written "Imagine language was a mathematical equation."
Does it matter?
Well, yes, actually. I'm English and I fully expect immigrants to adopt my language.
Fully.
pave said:So....what do you think,is it important![]()
sean5302 said:Yes, that's what I thought.
The problem is not just the immigrants, but our own natives haven't a clue about adverbs, subjunctives, pronouns.
I think it's called "dumbing down". Adopting the standards of the thickest.
Right or wrong.
Does it matter?
Fully.
Stuart Wright said:My particular take on bad spelling/grammar/punctuation is that as with anything else in life, people form an opinion based on a number of factors. Usually it's their appearance but obviously in the case of forums, I think it's the quality of their writing immediately and then what they are saying.
This is unfortunate for English speaking people who haven't had a good education, although everyone can improve their writing abilities if they are motivated enough to. They IMO they *should* be motivated since as I've mentioned, people will judge them by it. I'm afraid to say that the mistaken use of their instead of they're (and vice versa) does wind me up a bit.
People who's first language is not English should be forgiven more, I think.
And doink, I see you've edited your post to remove the link to a particular thread showing poor English. The post you were referring to was written by someone who's first language is Greek. Knowing that makes you look a bit foolish, I think.
Beyond writing ability, people often let themselves down with their laziness and bad habits.
I often leave a smelling pistake in my posts since I have such little time in the day, it's more important to me to get the point across than to worry about the odd pissmelt worm. And provided the point comes across clearly, I don't think most people are bothered about the odd mistake.
However, I find txt speak extremely annoying. There is absolutely no excuse for using it on the AV Forums, and heavy users will be politely asked to belt up.
The big point, I feel, is that omitting punctuation, using bad grammar and peppering your posts with similar mistakes makes your message harder to read. And surely you want people to understand your message?
So I would suggest that everyone put as much effort as they can into producing as high a quality writing style as possible. Good or bad, people will judge you by it and are more likely to respond to a 'reader friendly' message.
Ethics Gradient said:I am dyslexic. I aslo have only a limited amount of time inbetween work and the other issues that crop up to plague ourlives in which to read and respond to postings on the forum.
If I were to be filling in an application for a new job, writing a letter to some offical source or filling in a form, I could expect to be judged on my ability or lack thereof to use the correct grammar. However, in a reasonably fast paced medium such as the internet where people are attempting to communicate in the written word almost converstationally, I would not expect people to be so pedantic and judgemental.
What matters is the the idea's, meaning's and context of the poster's communication is basically understood.
I can quite accept that if people are using almost cryptic slang such as txt speach to contruct whole sentances that is it just not really acceptable.
examples:
its when you mean it is (it's) ..... or even it's when you mean the dogs bowl was in its mouth.
It is usually reasonably clear to most people. especially those with a reasonable education what the poster really means due to the context of the rest of the sentance or post.
For example, if I was to say the following:
Its not particularly nice to be so pedantic about people's posts.
It's quite clear what was being said ... you would generally be considered to have mental problems if you could not fluidly read the sentance and understand what is being said.
However, if I posted something along the lines of:
How R u, gtg bzr for a pnt l8r
..... I would expect to be slapped with a large wet fish
Some posters seem to attempt to riddicule posters and use simple and understandable mistakes in a veign attempt to negate the actual posters point.
I can quite accept that if this happens to be on the subject of grammar itself, then it's fair game, but not it is discussing the value of a particular flat screen monitor or the current priceing of dvd's.
It often smacks more of the criticising posters inhability to hold a reasonable arguement or be able to disprove the original posters point, than to the quality of the latters opinion.
I've not spell checked this post, and there are probably a few mistakes .... I simply don't care. I would pretty much consider any critic's post to be so analy retentive as to be petied![]()
