Hello,
I'm about to buy a new setup and I'm having a real dilemma.
I had waited for the SONY STR-DN1080 coming out as it ticked the boxes of almost all features I wanted with good sound quality, but also made my life simple as it fits in my existing tv cabinet . After a bit of research I'd decided on pairing it with the Q acoustics 3000 cinema pack.
When I came time to buy I realised that the cost of this was within a couple of hundred pounds of stepping up to the Yamaha A860 with the Monitor audio bronze 5.1 kit, or for a bit more again the A1060.
My room is just a bit more than 5 metres long x 4 metres wide, with the tv in a corner offset to the right of my viewing position due to a fireplace in the middle of the wall.
Initially I thought the SONY amp with the QA speakers was the best compromise between quality and cost that would suit the room. However, I am usually of the mind to buy the best I can at the time to save having to buy again later!
As a result the package deals on offer have me looking at the Yamaha rx-a1060 with the Monitor Audio bronze 5 5.1 kit. I know the specs say this should be a much better setup for the money, but will it be able to express itself in a room this size or would I essentially be buying a better but less suitable setup? Is it overkill for this room?
Many thanks
Many thanks
