T
taoyeah
B&W CHERRY NAUTILUS 805 much better than atlantic technology 4200e LR?planning to buy 1 of them.
I notice you are from the US and that also maybe why no one has been able to give a comparison of the Atlantic Technology 4200e speakers which i have not seen over here in the UK but may be mistaken, but the B&W Nautilus/800 series are very well known here and if you were to do a search in this Forum you will find alot of opinions ref to the 805's and what great speakers they are and come highly recommended as higher end standmount speakers.B&W CHERRY NAUTILUS 805 much better than atlantic technology 4200e LR?planning to buy 1 of them.
Joe has a very good point and it is so easy to throw a system together but whether it will sound any good is the problem, so choose carefully and it is always best in a 5.1 setup to have the front 3 speakers matching to give a good balance across the front 3 speakers.Assembling a 5.1 loudspeaker array is a tricky business - its very easy to put together a set up that doesn't have a cohesive balance to the sound it produces.
