This question is possibly more so directed for response from an appropriate Arcam engineer but anyone is welcome to input if it helps !!
I purchased the DV29 for its' unique ability to turn off progressive scan and output interlaced video (480i / 576i) via HDMI and then send it to my DVDO iScan VP30/ABT-102D video processor/scaler, which is fully HDMI compliant (I have been assured by DVDO) for processing.
What I have noticed is, if I go into the DV29 setup menu (Video page 2/7 ) and set it for : "Output Priority - HDMI/DVI" for HDMI compliance as indicated on page 14 of the DVD manual, the EDID tables' plug' n play implementation doesn't seem to like when you disable progressive scan and proceeds to re-enable it to "PAL only(625)" - also changes "TV System " from Auto to PAL and lose NTSC playback and changes the colourspace "Digital Video" setting from YUV to RGB with RGB disappearing.
Heres the interesting part, if I select : "Output Priority - Analogue", I can set all the settings as I prefer without anything being altered or the EDID table interfering, which seems to indicate that the handshake between the Arcam DV29 and the DVDO VP30 is now HDMI compliant !
Are these settings some how crossed ? - That is " Analogue" is indicating HDMI compliance and "HDMI/DVI" is not.
I have been assured by DVDO that their VP30/ABT-102D was fully HDMI compliant after their initial firmware upgrade.Their initial firmware was not compliant but allowed me to set "Output Priority to HDMI/DVI"
So who is fully compliant and who isn't - Arcam or DVDO ?
I believe Josh from DVDO is sending Arcam this information for review, so that it can be resolved hopefully. It seems both Arcam and DVDO are following and implementing Silicon Images "HDMI compliance " for their EDID Table but producing two different interpretations of compliance.
I hope I haven't left people scratching their heads - it can sound like double dutch. I need to lie down now because my head hurts
