Is anyone using a Phantom PVR with an HS2?
Discussion in 'Digital TV & Video Players & Recorders' started by DaveP, Oct 20, 2003.
Tags:
  1. DaveP
    DaveP
    I've got a Red Spot Remover and sometimes when I use the Sky Planner to change the channel prior to recording the RSR sends a Backup command halfway through the change and the channel doesn't change.
    I was thinking of getting a Phantom PVR but before I do, I'd like some feedback from anyone who is already using one!
    Dave
  2. Moo
    Moo
    I don't know which Red Spot Remover you've got, but this SkyEye is designed to work with the Programme Planner and not have the Back Up get in the way.
  3. DaveP
    DaveP
    Thanks mate, the one I've got sits in front of the Digibox and transmits a Backup command from an IR transmitter. Thanks for the link though. Maybe persuade my missus to buy it me for christmas!
    Dave
