Is anyone successfully using a Video Sender with an LCD TV
Discussion in 'LCD & LED LCD TVs Forum' started by Chris_R, Feb 6, 2005.
Tags:
  1. Chris_R
    Chris_R
    Hello,
    This weekend i have been attempting to to set up my AEI Digi Video Sender to my Relisys 17" LCD TV. I have the JS Technology RGB to Component (YUV) Video Converter and although properly connected all i get is Audio and no picture.
    I am beginning to think the JS Technology converter cannot deal with the wireless signal. If this is the case i fully understand as the converter i think is meant to be direct connected, no problem just disappointing.
    I would be interested to know if anyone is using a video sender with their LCD TV.
    Regards
    Chris
  2. richardr
    richardr
    May 11, 2001
    329
    28
    UK
    +49
    Are you sure the video sender sends RGB, and not just composite?
  3. Chris_R
    Chris_R
    You could be right, ive had the digisender quite a while, 2 years approx. That may explain why there is no picture. the Digisender receiver has a scart output so i will try a scart connector to composite to prove one way or the other. I can do this excluding the convertor too. Ultimately i want to use the converter to optimize the picture so i may end up having to get an RGB sender.
    Chris
