Is anyone else having problems with subtitles on Sky+?
Discussion in 'Sky Digital TV Forum' started by NicolasB, Jun 17, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    6,453
    Emily's Shop
    +898
    The most annoying thing that my Sky+ box currently does is to stop producing subtitles. If I reboot it (unplug it from the mains, then plug it back in) then it works for a day or so, but then stops producing them again. I wouldn't mind except that of course if you reboot it in the middle of a recording you lose the recording. :mad:
    And being partially deaf I make more use of subtitles than some people would.
    (sigh)
    I wondered if it might be a problem with the latest software update. Is anyone else having this problem, or is my box on the fritz? (It's out of its guarantee period now, sadly).
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I would suspect a software issue rather than a hardware issue and while a reboot loads the OS backup that's stored internally perhaps a full OS download might make a difference.
    One point about the warranty, while you own the hardware the software SKY+ runs remains the property of SKY and if that is causing a problem then it's reasonable to suggest that they have final responsibilty to ensure the software is installed correctly and working.
    Of course the CS reps are trained never to admit it could be SKY's fault !
