Is ANY Plasma immune..
Discussion in 'Plasma TVs Forum' started by beowulf, Jun 14, 2002.
  1. beowulf
    beowulf
    Jun 10, 2002
    934
    +28
    ..to the dreaded burn-in?
    Would hate to blw £10k on one - then get some of the horror stories , you hear about !
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    All phosphor based display devices are suceptible to burn in, be they plasma, crt monitors and tv's, front or rear projector.
    In proper set up of front panel controls is usual culprit. In proper use, once set up well, it's unlikely you'll get burn in unless you are one for watching Sky News all day....or another channel with a logo in top corner. Ifyou had contrast turned up on your normal TV and left it on a channel like that you'd trash it too.
    The only burnt plasma's I've seen have been in public installations where they have had static images being burnt in to them all day, 24 hrs a day every day... not clever....
    Gordon
  3. beowulf
    beowulf
    Jun 10, 2002
    934
    +28
    Cheers for that
    What a relief
    Im considering buying the beovison 5 . if I suffered burn in with this would I have to pay for the repair ?
  4. encaser
    encaser
    Mar 15, 2001
    3,374
    Suffolk/Essex
    +1,041
    I'm pretty sure there is NO plasma manu' who'll cover screen burn in their warranty - i.e. Pana/Fujitsu/NEC/Sony/Philips don't. And if screen burn does occur it's irrepairable, though some minor forms can be corrected or made less obvious.
    Many people think a plasma is just like a big pc monitor that can take the same sort of use/abuse and it's not the case.
  5. beowulf
    beowulf
    Jun 10, 2002
    934
    +28
    In other words.. dont bother with Plasma?
    If this Really is as bad as it sounds.. forget it !
    Does LCD suffer the same problem ?
  6. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    DLP and LCD projectors DO NOT suffer from burn-in. But CRT projectors can have burn-in issues.
