Is a VGA cable just a VGA cable??
Mickey123
Sorry, I'm sure this has been answered in one of my threads previously but I can't for the life or me remember the answer or find the thread:(
I'm about to buy a VGA/SVAG monitor extension cable to plug my 360 into my plasma. I have my seperates in a diff room so need to extend the MS cable but still want the best picture I can
With scarts etc you can buy gold plated etc etc diff quality that all make a vast diff to the end result.
Is VGA the same or is a VGA cable just a VGA cable being digital and all?:confused:
Also will a SVGA cable do the same as a VGA from my 360 to my Panny 6 series?
Many thanks
Mickey
daveon
If I remember rightly svga will give you a better quality for monitors over 17"
Mickey123
so is a VGA cable just the same as any and won't effect the Picture quality no matter how cheap or dear within reason?
T800
Mickey123
OK cool - so now all I need to know is........
are there differences cable to cable in quality as in SCARTS or is a VGA a VGA making no diff to end picture?
Mickey123
Oh mate,my head hurts. Im not so technical re cables and havent a clue what that thread is on about:eek: all thoes different cables???
Thanks for taking the time to supply the link though, appreciated
So do VGA cables differ in end picture quality from cable to cable?
Please somebody - and then I can get this thing ordered.
Mickey123 said:
Many thanks
Mickey
Last time I checked a VGA cable is well a VGA cable...and its analogue.
[email protected]
I have a standard VGA and a monster VGA and I can tell a big difference in picture quality between the two. The monster is a lot better colour reproduction and just generally seems clearer somehow. From my limited experience of VGA cables I would recommend the monster or if not then as with most cables, spend as much as you can afford on the best possible quality cable you can get as there is a difference .
T800
Mickey123
Thanks for the links guys!!
I think this one looks fitting for what I need and an OK price too
T800 - Its what you suggested but longer.
http://www.cableuniverse.co.uk/catalog/index.php?main_page=product_info&cPath=103&products_id=222
I looked at monter and they do a cable for around 50 quid !!
http://www.monstercable.com/UK/productPage.asp?pin=3672
This could of beejn of interest to me if they made it without the stereo connector (whay pay for what I won't use) and if they made a way of extending it by about 7 meters.
BY the way, look at the descrition for some of the worsted grammer ever to grace a web site. Space bar anyone haha
Again, thanks for your patients and links
EDIT - Have bought first link ^^^^ cable.
I use the component cables by Monster which cost £50 I am happy with them, but no so happy that I dont think I can see much difference, if any.
Mickey123
Sorry mate - are you saying you CAN'T see a diff or CAN?
Between what? Monster cables and another brand or Monster cables and standard 'comes with the product' cables?
Similar threads
Trending threads
