Is a subwoofer cable different to a phono cable?
Ash007
Joined
Dec 29, 2001
Messages
219
Reaction score
Points
156
Age
49
Location
Rochdale
Is a subwoofer cable different to a phono cable (i'm thinking of the red and white jobies you get with any hifi equipment), or are they the same thing?
Ash
I believe so, but whether or not anyone can audibly tell the difference.............. I got a longer one I needed off Ebay - OFC, Gold plated plugs etc for under a tenner & I have no complaints about performance. It looked a lot better quality than the one supplied.
Given that the sub cable is likely to travel further and through more electrically hostile environments (i.e. the floor, near power sockets etc.) it is better to get something that is well shielded etc.
I tried a number of long phonos and others and settled on this (5m length):
http://www.cybermarket.co.uk/ishop/923/shopscr288.html
No interference or noise even with the sub turned up to full (and the other end of the cable plugged into a switched OFF amp!) - which is a good test for mains hum etc.
With an old cable I used to hear some random TV or radio station induced as a low bass. Sounded like my neighbor had their TV turned up a long way until one day I turned the sub off - and silence. I swapped cables sharpish.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
