Is a SONY VPH1270 CRT remote the same as a sony D50 remote
Discussion in 'Projectors, Screens & Video Processors' started by Greg Lancaster, Aug 25, 2005.
  1. Greg Lancaster
    Greg Lancaster
    Aug 23, 2005
    63
    Uttoxeter
    Hi can anyone tell me if the SONY VPH1270 remote is the same a a D50
    all the bes Greg
  2. theult
    theult
    I know they will work, but a couple of the buttons are labelled differently...
    To get into the service menu on the 1270, you hold in "test" on the d50, I believe it's "enter, enter, up, down, enter". Plus, I believe the d50 has a "pattern" button instead of a "test" button. Other than that, I think they are identical.
    I have a 1272 sitting in front of me right now, but not a D50, so this is from memory.
    Thank you,
    Jeff Homan
