Quantcast
Is a ps4 ok to stream 4k netflix
md1985
I wasnt sure if the ps4 was good enough for 4k netflix or not? I know it has been said if you wish to get the most out of it a ps4 pro is better but is this only if you're worried about hdr?
I currently have a standard ps4 and just bought a Philips 43PUS7303 and was thinking of upping my netflix to premium for a bit of 4k stuff.
next010
The regular PS4 has a max 1080p output, it cannot output a 2160p/4K signal, only the PS4 Pro can in the Playstation line up.
Your TV is an AndroidTV so should have access to the Netflix app which will stream in 4K.
